メインコンテンツにスキップ
Canon EOS Rebel T2i Strap Anchor Replacement
必要な工具と部品
  1. Canon EOS Rebel T2i Strap Anchor Replacement, I/F Terminal Cover: 手順 1、 3の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, I/F Terminal Cover: 手順 1、 3の画像 2 Canon EOS Rebel T2i Strap Anchor Replacement, I/F Terminal Cover: 手順 1、 3の画像 3
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i Strap Anchor Replacement, Remove the back casing.: 手順 2、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, Remove the back casing.: 手順 2、 2の画像 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i Strap Anchor Replacement: 手順 3、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 3、 2の画像 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i Strap Anchor Replacement, Open the back panel.: 手順 4、 3の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, Open the back panel.: 手順 4、 3の画像 2 Canon EOS Rebel T2i Strap Anchor Replacement, Open the back panel.: 手順 4、 3の画像 3
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i Strap Anchor Replacement, Front Cover: 手順 5、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, Front Cover: 手順 5、 2の画像 2
    • Remove the following screws from the front of the camera:
    • Two M1.7x5.5mm JIS #000 screws
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
  6. Canon EOS Rebel T2i Strap Anchor Replacement: 手順 6、 3の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 6、 3の画像 2 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 6、 3の画像 3
    • Slide a spudger tool towards the tripod mount, underneath the plastic cover.
    • Push the plastic cover up and over the tripod mount.
    • Pull the front cover off of the camera.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
  7. Canon EOS Rebel T2i Strap Anchor Replacement, Top Casing: 手順 7、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, Top Casing: 手順 7、 2の画像 2
    • Remove the screws next to the viewfinder:
    • One M2.0x8.9mm JIS #000 diopter screw
    • Remove the following screws from the top of the camera:
    • One M1.7x2.5mm JIS #000 screw
    • One M1.7x5.0mm Phillips #000 screw
  8. Canon EOS Rebel T2i Strap Anchor Replacement: 手順 8、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 8、 2の画像 2
    • Disconnect the microphone cable from the main PCB board.
    • Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
    • Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
    • If you do not have a flathead 2.5mm screwdriver, another similarly sized flathead screwdriver should work.
  9. Canon EOS Rebel T2i Strap Anchor Replacement: 手順 9、 3の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 9、 3の画像 2 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 9、 3の画像 3
    • Locate the ribbon cable which connects the top cover the main PCB board.
    • Use a plastic spudger tool to carefully pry off the connector.
    • Use caution when handling ribbon connectors and their connectors.
    • Take note of where this fiber optic cable connects to the main PCB board.
    • The cable will slide out of the connector when you pull the top cover off. You will need to remember to slide this cable back into the connector with a pair of tweezers when reinstalling the top cover. This cable is crucial for the function of the camera flash.
  10. Canon EOS Rebel T2i Strap Anchor Replacement: 手順 10、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement: 手順 10、 2の画像 2
    • Disconnect these two cables connected to the DC PCB board.
    • Use the same method as with removing the microphone cable, except with using a flathead 3.0mm screwdriver.
    • Gently wiggle the flathead screwdriver back and forth until the connectors comes free.
    • If you do not have a flathead 3.0mm screwdriver, another slightly larger flathead screwdriver should work.
    • Gently lift the top cover up and off of the camera body, being careful that the loose cables do not snag on anything.
  11. Canon EOS Rebel T2i Strap Anchor Replacement, Strap Anchor: 手順 11、 2の画像 1 Canon EOS Rebel T2i Strap Anchor Replacement, Strap Anchor: 手順 11、 2の画像 2
    • On the left side of the camera, remove the following screws:
    • Two M2.0x2.5mm JIS #000 screws
    • On the right side of the camera, remove the following screws:
    • Two M2.0x6.0mm JIS #000 screws
終わりに
添付文書
作成者
1人の作成者と共同作成されました。
Zephosk
メンバー登録日: 09/26/24
4,561 ポイント
29のガイドは作成済み
チーム
LGBTQ Technicians LGBTQ Technicians人のメンバー
Community
34 メンバー
98のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 11
