メインコンテンツにスキップ
Canon EOS Rebel T2i LCD Screen Assembly Replacement
必要な工具と部品
  1. Canon EOS Rebel T2i LCD Screen Assembly Replacement, I/F Terminal Cover: 手順 1、 3の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement, I/F Terminal Cover: 手順 1、 3の画像 2 Canon EOS Rebel T2i LCD Screen Assembly Replacement, I/F Terminal Cover: 手順 1、 3の画像 3
    • Before beginning, ensure that the camera is off, and the battery is removed.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x2.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T2i LCD Screen Assembly Replacement, Remove the back casing.: 手順 2、 2の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement, Remove the back casing.: 手順 2、 2の画像 2
    • On the left side of the camera, remove the following screw:
    • One M1.7x6.0mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 3、 2の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 3、 2の画像 2
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x2.5mm JIS #000 screws
  4. Canon EOS Rebel T2i LCD Screen Assembly Replacement, Open the back panel.: 手順 4、 3の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement, Open the back panel.: 手順 4、 3の画像 2 Canon EOS Rebel T2i LCD Screen Assembly Replacement, Open the back panel.: 手順 4、 3の画像 3
    • Slide the viewfinder eyepiece vertically upwards.
    • Start to pull the back cover partially off of the camera.
    • Use caution when removing the back cover, there is a ribbon cable that connects the LCD screen to the main PCB board.
    • Disconnect the LCD screen ribbon cable from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Carefully pull out the ribbon cable from its connector using a pair of angled tweezers.
    • Finish pulling the back cover off of the camera body.
  5. Canon EOS Rebel T2i LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 5、 3の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 5、 3の画像 2 Canon EOS Rebel T2i LCD Screen Assembly Replacement, LCD Screen Assembly: 手順 5、 3の画像 3
    • Use extreme care while handling ribbon cables and connectors as they can be easy to damage.
    • Use a plastic spudger to lift up the locking tabs on the two ribbon cable connectors.
    • iFixit connector guide
    • Remove the four ribbon cables connected to the FPC assembly.
    • Stick one of the ends of a pair of pointed tweezers through the hole in the ribbon cable and carefully pull the ribbon cable out of each connector.
  6. Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 6、 2の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 6、 2の画像 2
    • Remove the following screws from the back cover FPC assembly:
    • One M1.7x4.0mm JIS #000 screw
    • Carefully slide out the back cover FPC assembly from underneath the metal tabs holding it in place.
  7. Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 7、 3の画像 1 Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 7、 3の画像 2 Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 7、 3の画像 3
    • Remove the following screws on the LCD screen assembly:
    • Five M1.7x3.5mm JIS #000 screws
    • Pull off the metal holding plate.
    • With a pair of angled tweezers, carefully pull off the DOS FPC assembly.
  8. Canon EOS Rebel T2i LCD Screen Assembly Replacement: 手順 8、 1の画像 1
    • Gently lift up the right side of the LCD screen and pull it off of the back cover.
    • Before installing a new LCD screen, ensure that there is no dust on the inside of the LCD window.
終わりに
ある他の人がこのガイドを完成しました。
添付文書
作成者
1人の作成者と共同作成されました。
Zephosk
メンバー登録日: 09/26/24
5,457 ポイント
34のガイドは作成済み
チーム
LGBTQ Technicians LGBTQ Technicians人のメンバー
Community
47 メンバー
77のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 307
