この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show users how to access the rear button contact in order to replace or clean the button contacts. It is not necessary to remove the LCD or speaker in order to perform this guide.
必要な工具と部品
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
Remove each of the four 4.8 mm screws holding the protective plate over the button contact ribbon cable.
4 の人々がこのガイドを完成させました。
2 件のコメント
My 5D Mark II buttons work fine in auto mode, but don’t function in other modes. IE Manual, AV, TV ETC. Do you think this is a button residue issue? My camera may have taken on some water during my last shoot. What fix would you suggest?
