メインコンテンツにスキップ
Canon EOS 30 Battery Door Replacement
必要な工具と部品
  1. Canon EOS 30 Battery Door Replacement, Front Panel: 手順 1、 1の画像 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Battery Door Replacement: 手順 2、 1の画像 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Battery Door Replacement: 手順 3、 1の画像 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Battery Door Replacement: 手順 4、 1の画像 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Battery Door Replacement, Bottom Panel: 手順 5、 1の画像 1
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Canon EOS 30 Battery Door Replacement: 手順 6、 1の画像 1
    • Remove the bottom panel.
  7. Canon EOS 30 Battery Door Replacement, Side Panel With Remote Control Socket: 手順 7、 1の画像 1
    • Remove two 6.5 mm black screws from the panel.
  8. Canon EOS 30 Battery Door Replacement: 手順 8、 1の画像 1
    • Remove the plastic remote control socket cap by pulling it straight out.
  9. Canon EOS 30 Battery Door Replacement: 手順 9、 2の画像 1 Canon EOS 30 Battery Door Replacement: 手順 9、 2の画像 2
    • Slide the panel toward the bottom of the camera to remove.
  10. Canon EOS 30 Battery Door Replacement: 手順 10、 1の画像 1
    • Remove the single 4.8 silver screw from the control socket.
  11. Canon EOS 30 Battery Door Replacement: 手順 11、 2の画像 1 Canon EOS 30 Battery Door Replacement: 手順 11、 2の画像 2
    • The control socket is now secure by three wires.
    • Desolder connections to replace the remote control socket.
  12. Canon EOS 30 Battery Door Replacement, Top Panel: 手順 12、 1の画像 1
    • Slide the outer eyepiece upward to remove it.
  13. Canon EOS 30 Battery Door Replacement: 手順 13、 1の画像 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  14. Canon EOS 30 Battery Door Replacement: 手順 14、 1の画像 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  15. Canon EOS 30 Battery Door Replacement: 手順 15、 2の画像 1 Canon EOS 30 Battery Door Replacement: 手順 15、 2の画像 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  16. Canon EOS 30 Battery Door Replacement, Grip: 手順 16、 1の画像 1
    • Remove the two 5.5 mm screws from front of camera.
  17. Canon EOS 30 Battery Door Replacement: 手順 17、 1の画像 1
    • Remove grip panel.
  18. Canon EOS 30 Battery Door Replacement, Battery Door: 手順 18、 1の画像 1
    • Remove one black screw from battery door on underside of grip.
  19. Canon EOS 30 Battery Door Replacement: 手順 19、 1の画像 1
    • Remove battery door.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Jackie
メンバー登録日: 04/17/11
257 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011人のメンバー
CPSU-REGAN-S11S8G8
5 メンバー
22のガイドは作成済み
コメント 1 件
I was able to complete this by going from step 9 to 15. Oddly, I only had one screw to remove in step 15 but the grip piece easily slid out without needing to remove the top of the camera.
Alan - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 15
今までの合計 4,360
