メインコンテンツにスキップ
Canon EOS 20D Rear Case Replacement
必要な工具と部品
  1. Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: 手順 1、 2の画像 1 Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: 手順 1、 2の画像 2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Rear Case Replacement, Remove screws from under the eyepiece cap: 手順 2、 1の画像 1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 手順 3、 3の画像 1 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 手順 3、 3の画像 2 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 手順 3、 3の画像 3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Rear Case Replacement, Remove bottom screws: 手順 4、 1の画像 1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 手順 5、 3の画像 1 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 手順 5、 3の画像 2 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 手順 5、 3の画像 3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alec M
メンバー登録日: 05/08/16
1,282 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 24
今までの合計 1,396
