メインコンテンツにスキップ
Canary CAN100USBK Ethernet PCB Board Replacement
必要な工具と部品
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 手順 1、 2の画像 1 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: 手順 1、 2の画像 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 2、 1の画像 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 3、 3の画像 1 Canary CAN100USBK Ethernet PCB Board Replacement: 手順 3、 3の画像 2 Canary CAN100USBK Ethernet PCB Board Replacement: 手順 3、 3の画像 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 4、 2の画像 1 Canary CAN100USBK Ethernet PCB Board Replacement: 手順 4、 2の画像 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 5、 2の画像 1 Canary CAN100USBK Ethernet PCB Board Replacement: 手順 5、 2の画像 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: 手順 6、 1の画像 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 7、 2の画像 1 Canary CAN100USBK Ethernet PCB Board Replacement: 手順 7、 2の画像 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Ethernet PCB Board Replacement: 手順 8、 1の画像 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
終わりに
作成者
2人の作成者と共同で作成されました。
Tommy Nguyen
メンバー登録日: 02/28/17
597 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017人のメンバー
USFT-NANCE-S17S1G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 939
