メインコンテンツにスキップ
Canary CAN100USBK Audio and USB PCB Board Replacement
必要な工具と部品
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 手順 1、 2の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: 手順 1、 2の画像 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 2、 1の画像 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 3、 3の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 3、 3の画像 2 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 3、 3の画像 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 4、 2の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 4、 2の画像 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 5、 2の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 5、 2の画像 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: 手順 6、 1の画像 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 7、 2の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 7、 2の画像 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 8、 1の画像 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: 手順 9、 1の画像 1
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 10、 3の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 10、 3の画像 2 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 10、 3の画像 3
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 11、 1の画像 1
    • Remove the two Phillips #0 5mm screws.
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 12、 2の画像 1 Canary CAN100USBK Audio and USB PCB Board Replacement: 手順 12、 2の画像 2
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kristopher Gates
メンバー登録日: 02/28/17
399 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S1-G2, Nance Spring 2017 USF Tampa, Team S1-G2, Nance Spring 2017人のメンバー
USFT-NANCE-S17S1G2
4 メンバー
16のガイドは作成済み
2 件のコメント
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - 返信
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 827
