はじめに
This guide will go over how to replace an LED on your CM Storm Quickfire Rapid keyboard.
必要な工具と部品
Insert the keycap puller around the key with the defective LED and pull upward.
2 の人々がこのガイドを完成させました。
4件のガイドコメント
What kind of leds is it? Where can I get them?
3 mm white leds. I don’t know what voltage or effect they should be at though. I’m guessing 10-20 mA at around 2V, but mind you I’m just guessing… :(
So I'm having an issue with the LED backlight -- not a single LED, I mean the entire backlight. The FN key and the windows lock key (f12) light up when they are supposed to, but the function keys that are supposed to toggle on and off the rest of the backlight no longer do so (f1-f4 keys). Yet the f1-f4 keys clearly work, for instance, pressing f1 brings up the Chrome help menu, as intended. Any idea whether this is fixable, or how? I assume there is some circuit that controls the toggling on/off of the backlight for most of the keys, so maybe an issue with that?
Thanks for any suggestions.
