メインコンテンツにスキップ
Brother CS6000i Sewing Light Replacement
必要な工具と部品
  1. Brother CS6000i Sewing Light Replacement, Body: 手順 1、 2の画像 1 Brother CS6000i Sewing Light Replacement, Body: 手順 1、 2の画像 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: 手順 2、 2の画像 1 Brother CS6000i Sewing Light Replacement: 手順 2、 2の画像 2
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: 手順 3、 2の画像 1 Brother CS6000i Sewing Light Replacement: 手順 3、 2の画像 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: 手順 4、 3の画像 1 Brother CS6000i Sewing Light Replacement: 手順 4、 3の画像 2 Brother CS6000i Sewing Light Replacement: 手順 4、 3の画像 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: 手順 5、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: 手順 6、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: 手順 7、 1の画像 1
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: 手順 8、 1の画像 1
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: 手順 9、 1の画像 1
    • Remove the light.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
作成者
3人の作成者と共同で作成されました。
Aidan Lear
メンバー登録日: 10/31/24
121 ポイント
1ガイドが承認済み
チーム
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024人のメンバー
CUESTA-KRYNEN-F24S20G1
5 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 30
今までの合計 83
