メインコンテンツにスキップ
Bosch IXO (2 Gen) Battery Replacement
必要な工具と部品
  1. Bosch IXO (2 Gen) Battery Replacement, Unscrew screws: 手順 1、 1の画像 1
    • Loosen 4 screws size Torx T10. The screw size is identical for all four screws.
    • All four screws are the same length.
  2. Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: 手順 2、 3の画像 1 Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: 手順 2、 3の画像 2 Bosch IXO (2 Gen) Battery Replacement, Detaching the type plate: 手順 2、 3の画像 3
    • Loosen the nameplate on the bottom of the screwdriver and set it aside so that the right housing part can be removed in the next step.
  3. Bosch IXO (2 Gen) Battery Replacement, Open housing: 手順 3、 2の画像 1 Bosch IXO (2 Gen) Battery Replacement, Open housing: 手順 3、 2の画像 2
    • The housing halves now lie loosely on top of each other. Lift the right housing half upwards and set it aside.
    • It may be that the two halves of the case stick together quite strongly due to the gasket in between. Then shake it delicately and pull vigorously. :)
  4. Bosch IXO (2 Gen) Battery Replacement, Locate battery: 手順 4、 2の画像 1 Bosch IXO (2 Gen) Battery Replacement, Locate battery: 手順 4、 2の画像 2
    • The green battery can be found in the red border.
    • The battery is labeled with: INR18650-13P SAMSUNG SDI 076
    • You can find it for example at Amazon or eBay, if you search for "Samsung 18650 13P solder tag
  5. Bosch IXO (2 Gen) Battery Replacement, De-Soldering the battery: 手順 5、 2の画像 1 Bosch IXO (2 Gen) Battery Replacement, De-Soldering the battery: 手順 5、 2の画像 2
    • Heat the cables at both pole ends with a soldering iron and detach them.
    • In this tutorial, you will learn how to solder and desolder.
    • Please dispose of the battery properly at local disposal points.
  6. Bosch IXO (2 Gen) Battery Replacement, Soldering of the new battery: 手順 6、 1の画像 1
    • Connect the side of the new battery with the white ring (positive pole +) to the red cable. Solder the blue cable to the other side (without the white ring).
終わりに
To reassemble the device, follow the steps in reverse order
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
BenZ78
メンバー登録日: 10/15/19
19,816 ポイント
3のガイドは作成済み
5件のガイドコメント
Danke für die glasklaren Anweisungen!
FRITZ WIDRIG - 返信
Sehr gerne, freut mich, dass es geklappt hat :-)
BenZ78 -
Supe,r danke
Rainer - 返信
Is it okay to replace the battery with a new one that has a BMS (Battery Management System) on it? The BMS is in a form of small pcb strip, and that pcb is inside the protection jacket of the battery. TIA.
Leebid - 返信
Yes, just make sure the new battery has the same length as the once installed, and that the new battery can handle 18 amps of continuous discharge.
Andrew S -
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 88
過去 30 日: 367
今までの合計 13,266
