このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Tools needed: Plastic pry tool, Philips screw driver
Issue description: When in auto zoom mode, the flash continue to show a flashing "50mm" (as appropriate for bounced lighting) even if the head is facing straight. It is caused by a broken wire that connects to a switch meant to inform the flash's electronics that the head is now locked in the "straight" position.
この手順は未翻訳です。 翻訳を手伝う。
This reveals four screws on either side of the flash. Remove the upper two on either side.
You may find it helpful to remove the lower two as well to access the wire in the next step, but for now it is easier to keep them in place. This way you have fewer loose parts to handle.
この手順は未翻訳です。 翻訳を手伝う。
Pry the upper and the lower part of the upper housing apart using a plastic pry tool. Do so in a motion that pushes the upper half inwards (towards the electronics), so as to unlatch the little plastic latches (see next photo) before pulling the halves apart.
There is one latch towards the front (lens side) of the flash on either side. After loosening both the upper part of the housing can be removed.
Remove the upper half of the cover completely.
この手順は未翻訳です。 翻訳を手伝う。
Now remove the lower two screws as well. Pull away the lower half of the cover just enough to reveal the two contacts (1) and (2)
When the flash head is pointed straight, these two make contact and enable auto zoom.
In my case, the blue wire attached to the little gold spring at contact (1) was broken. Resoldering the wire to the rear end of the golden spring fixed the issue.
この手順は未翻訳です。 翻訳を手伝う。
To reassemble proceed in opposite order. When positioning the plastic caps at the very end, note that they are not just flat discs, but need to be glued on in a specific rotational position.
Carefully move the head up and down a couple of times after reassembly to move the wires into their correct positions under the plastic cover. If you encounter significant resistance, you may have to disassemble again and check for the correct positioning of the wires.
Good luck!
ある他の人がこのガイドを完成しました。
