この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your buttons are unresponsive or become difficult to push, then your keypad is probably damaged or dirty. Use these step-by-step instructions to replace your BlackBerry Tour 9630 keypad.
必要な工具と部品
If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
もう少しです!
終わりに
