If there is an SD card, press gently on the card and slide up to remove.
If there is a SIM card, press gently on the card and slide left to remove.
Use the T6 Torx screwdriver to remove the four 8.00mm screws from the back of the phone.
Using the large blue plastic opening tool, pry the top plastic covering off.
There is glue holding the top plastic covering. Additional pressure may be needed.
Gently push up on the keyboard and snap the front cover off.
Once you remove the front cover, the keypad and trackball will be loose.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
