メインコンテンツにスキップ
BlackBerry PlayBook Motherboard Replacement
必要な工具と部品
  1. BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: 手順 1、 2の画像 1 BlackBerry PlayBook Motherboard Replacement, Remove Back Panel: 手順 1、 2の画像 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Motherboard Replacement, Motherboard: 手順 2、 2の画像 1 BlackBerry PlayBook Motherboard Replacement, Motherboard: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the battery connector using either your fingers or a pair of tweezers.
  3. BlackBerry PlayBook Motherboard Replacement: 手順 3、 2の画像 1 BlackBerry PlayBook Motherboard Replacement: 手順 3、 2の画像 2
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  4. BlackBerry PlayBook Motherboard Replacement: 手順 4、 2の画像 1 BlackBerry PlayBook Motherboard Replacement: 手順 4、 2の画像 2
  5. BlackBerry PlayBook Motherboard Replacement: 手順 5、 2の画像 1 BlackBerry PlayBook Motherboard Replacement: 手順 5、 2の画像 2
  6. BlackBerry PlayBook Motherboard Replacement: 手順 6、 3の画像 1 BlackBerry PlayBook Motherboard Replacement: 手順 6、 3の画像 2 BlackBerry PlayBook Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  7. BlackBerry PlayBook Motherboard Replacement, Unscrew Motherboard: 手順 7、 1の画像 1
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  8. BlackBerry PlayBook Motherboard Replacement, Remove Wire Leads: 手順 8、 1の画像 1
  9. BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: 手順 9、 2の画像 1 BlackBerry PlayBook Motherboard Replacement, Remove Motherboard: 手順 9、 2の画像 2
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
終わりに
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Nathan
メンバー登録日: 10/12/14
673 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G27
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 3,353
