メインコンテンツにスキップ
BlackBerry PlayBook Front Panel Replacement
必要な工具と部品
  1. BlackBerry PlayBook Front Panel Replacement, Remove Back Panel: 手順 1、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove Back Panel: 手順 1、 2の画像 2
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Front Panel Replacement, Unscrew Left Speaker: 手順 2、 1の画像 1
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Front Panel Replacement, Remove the Left Speaker Stickers: 手順 3、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove the Left Speaker Stickers: 手順 3、 2の画像 2
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Front Panel Replacement, Remove Left Speaker: 手順 4、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove Left Speaker: 手順 4、 2の画像 2
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Front Panel Replacement, Unscrew Right Speaker: 手順 5、 1の画像 1
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Front Panel Replacement, Remove Right Speaker: 手順 6、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove Right Speaker: 手順 6、 2の画像 2
    • Lift the right speaker bar to remove it.
  7. BlackBerry PlayBook Front Panel Replacement, Motherboard: 手順 7、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Motherboard: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the battery connector using either your fingers or a pair of tweezers.
  8. BlackBerry PlayBook Front Panel Replacement: 手順 8、 2の画像 1 BlackBerry PlayBook Front Panel Replacement: 手順 8、 2の画像 2
    • Unscrew two 1.17x2.9mm Phillips screws from the white connector port.
    • Lift the battery connector away from the motherboard using a spudger.
  9. BlackBerry PlayBook Front Panel Replacement: 手順 9、 2の画像 1 BlackBerry PlayBook Front Panel Replacement: 手順 9、 2の画像 2
  10. BlackBerry PlayBook Front Panel Replacement: 手順 10、 2の画像 1 BlackBerry PlayBook Front Panel Replacement: 手順 10、 2の画像 2
  11. BlackBerry PlayBook Front Panel Replacement: 手順 11、 3の画像 1 BlackBerry PlayBook Front Panel Replacement: 手順 11、 3の画像 2 BlackBerry PlayBook Front Panel Replacement: 手順 11、 3の画像 3
    • Remove the clipped ZIF data connector coming from underneath the motherboard.
    • Lift up the black plastic clip with a spudger.
    • Pull the connector out gently using tweezers.
    • Be careful to ensure that the black plastic clip has been lifted away from the connector ribbon before pulling on the connector. The clip should be loose and easy to wiggle. Removing the connector before it is unclipped can cause damage.
  12. BlackBerry PlayBook Front Panel Replacement, Unscrew Motherboard: 手順 12、 1の画像 1
    • Remove the following five screws from the motherboard.
    • Three 1.5x2.5mm Phillips screws
    • Two 1.55x2.38mm Phillips screws
  13. BlackBerry PlayBook Front Panel Replacement, Remove Wire Leads: 手順 13、 1の画像 1
  14. BlackBerry PlayBook Front Panel Replacement, Remove Motherboard: 手順 14、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove Motherboard: 手順 14、 2の画像 2
    • Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
  15. BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 手順 15、 3の画像 1 BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 手順 15、 3の画像 2 BlackBerry PlayBook Front Panel Replacement, Unscrew Mid-Frame: 手順 15、 3の画像 3
    • Remove both screws attaching the metal mid-frame to the front panel.
    • Two Phillips screws
  16. BlackBerry PlayBook Front Panel Replacement, Unscrew Boards from Mid-Frame: 手順 16、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Unscrew Boards from Mid-Frame: 手順 16、 2の画像 2
    • Unscrew the small blue boards in each corner with the same Phillips screwdriver.
  17. BlackBerry PlayBook Front Panel Replacement, Peel Off Sticker: 手順 17、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Peel Off Sticker: 手順 17、 2の画像 2
    • Remove the sticker holding the touchscreen controller in place to free it from the mid-frame.
  18. BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 手順 18、 3の画像 1 BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 手順 18、 3の画像 2 BlackBerry PlayBook Front Panel Replacement, Unclip Mid-Frame: 手順 18、 3の画像 3
    • Unclip all attachments along the sides of the tablet.
    • Two large clips on the top of the device.
    • Four medium clips on the bottom of the device.
    • One small clip on the side of the device, near the headphone jack.
    • This last clip is particularly difficult and might require a sharper tool to remove.
  19. BlackBerry PlayBook Front Panel Replacement, Lift Mid-Frame: 手順 19、 1の画像 1
    • Gently lift the metal mid-frame away from the front panel.
    • A connector runs through a hole in the mid-frame under the area where the motherboard used to rest. While lifting, ensure that this connector is properly fed through the hole.
  20. BlackBerry PlayBook Front Panel Replacement, Unscrew Display: 手順 20、 1の画像 1
    • Remove the one remaining Phillips screw holding the display in place.
  21. BlackBerry PlayBook Front Panel Replacement, Remove Display: 手順 21、 2の画像 1 BlackBerry PlayBook Front Panel Replacement, Remove Display: 手順 21、 2の画像 2
    • Gently lift the display out of place.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Keyon Keshtgar
メンバー登録日: 10/11/14
433 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-27, Maness Fall 2014 Cal Poly, Team 14-27, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G27
4 メンバー
12のガイドは作成済み
コメント 1 件
Where can I get a blackberry playbook screen am in Kenya
Emily Opondo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 29
今までの合計 5,179
