メインコンテンツにスキップ
Black and Decker LI4000 Voltage Regulator Board Replacement
必要な工具と部品
  1. Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: 手順 1、 3の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: 手順 1、 3の画像 2 Black and Decker LI4000 Voltage Regulator Board Replacement, Outer Casing: 手順 1、 3の画像 3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 2、 1の画像 1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 3、 2の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 3、 2の画像 2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 4、 2の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 4、 2の画像 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
  5. Black and Decker LI4000 Voltage Regulator Board Replacement, Voltage Regulator Board: 手順 5、 2の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement, Voltage Regulator Board: 手順 5、 2の画像 2
    • Locate the negative terminal of the battery.
    • Remove the negative (black) wire by pulling back gently.
  6. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 6、 3の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 6、 3の画像 2 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 6、 3の画像 3
    • Gently pull up on the end of the battery closest to the negative terminal. Pulling the battery up should reveal the positive (red) wire located on the opposite end of the battery.
    • To free battery, gently pull back on the positive (red) wire.
  7. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 7、 2の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 7、 2の画像 2
    • Set battery aside in a safe place.
    • Locate the voltage regulator board near back midsection of the handle on the screwdriver.
    • Slowly pull up on the voltage regulator board.
    • Keep in mind the voltage regulator board is wired to all other boards. Use caution when removing to prevent causing damaging to wiring
  8. Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 8、 3の画像 1 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 8、 3の画像 2 Black and Decker LI4000 Voltage Regulator Board Replacement: 手順 8、 3の画像 3
    • Locate the four soldering joints (two connected to battery contact board and two connected trigger/switch board).
    • iFixit has a quick tutorial on soldering here.
終わりに
作成者
2人の作成者と共同で作成されました。
Nigel Leitzell
メンバー登録日: 02/11/16
463 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 29
今までの合計 416
