メインコンテンツにスキップ
Black and Decker LI2000 Circuit Board Replacement
必要な工具と部品
  1. Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 手順 1、 3の画像 1 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 手順 1、 3の画像 2 Black and Decker LI2000 Circuit Board Replacement, Orange Casing: 手順 1、 3の画像 3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Circuit Board Replacement: 手順 2、 1の画像 1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Circuit Board Replacement: 手順 3、 1の画像 1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Circuit Board Replacement: 手順 4、 1の画像 1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Circuit Board Replacement, Handle: 手順 5、 2の画像 1 Black and Decker LI2000 Circuit Board Replacement, Handle: 手順 5、 2の画像 2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Circuit Board Replacement: 手順 6、 2の画像 1 Black and Decker LI2000 Circuit Board Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Circuit Board Replacement, Battery: 手順 7、 2の画像 1 Black and Decker LI2000 Circuit Board Replacement, Battery: 手順 7、 2の画像 2
    • Using pliers or your fingers, remove the leads off of the battery.
  8. Black and Decker LI2000 Circuit Board Replacement, Circuit Board: 手順 8、 1の画像 1
    • Refer to the Soldering Technique Guide to remove the wires on the circuit board that connect the charging adapter by applying heat from iron to existing solder on the board.
    • Keep track of which wire connected to which part of the board.
  9. Black and Decker LI2000 Circuit Board Replacement: 手順 9、 1の画像 1
    • Refer to the Soldering Technique Guide to remove the wires from the circuit board that connect to the battery by heating the existing solder on the leads.
    • Keep track of which wire was connected to which part of the circuit board.
終わりに
作成者
2人の作成者と共同で作成されました。
Katherine Simmons
メンバー登録日: 02/08/16
732 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 1-3, Baechle Spring 2016 IUPUI, Team 1-3, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S1G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 535
