はじめに
Instructions for removing/replacing the small drive belt (transaxle belt). This belt must also be removed in order to service the larger blade/spindle belt.
必要な工具と部品
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
Relieve the tension on the transaxle drive belt by pressing on the back end of the tensioning arm. (Alternatively, use a pry bar on the front end of the tensioning arm, or remove the tensioning spring.)
Slip the transaxle drive belt off the drive pulley.
4 の人々がこのガイドを完成させました。
