はじめに
Follow these instructions to replace a damaged throttle control. Optionally, you may also replace the attached throttle control cable.
必要な工具と部品
Use a Phillips #2 driver to remove the two screws securing the throttle control.
While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
もう少しです!
終わりに
4 の人々がこのガイドを完成させました。
