メインコンテンツにスキップ
Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement
必要な工具と部品
  1. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 手順 1、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 手順 1、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Cable: 手順 1、 3の画像 3
    • Cut and remove any zip ties securing the throttle cable.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 2、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 2、 2の画像 2
    • Use a Phillips #2 driver to remove the screw securing the lower end of the throttle cable.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 3、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 3、 2の画像 2
    • Remove the bracket securing the lower end of the throttle cable.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 4、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 4、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 4、 3の画像 3
    • Rotate the lower end of the throttle cable to detach it from the throttle.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 5、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 5、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 5、 3の画像 3
    • When reinstalling the throttle control cable, check to make sure that the throttle control moves the throttle through its full range of motion.
    • If necessary, loosen the screw securing the lower end of the throttle cable and adjust the position of the cable. Re-tighten the screw and check to make sure that the throttle moves through its full range of motion.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 6、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 6、 2の画像 2
    • Use a 7/16" wrench or deep socket to remove the cap from the throttle control.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 7、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 7、 2の画像 2
    • Advance the throttle control to expose the gear rack containing the upper end of the throttle cable.
  8. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 8、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 8、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 8、 3の画像 3
    • Separate the gear rack from the upper end of the throttle cable.
    • Lift and remove the gear rack from the throttle control.
    • If the gear rack doesn't fully detach, advance the throttle control lever a little farther.
    • Lubricate the gear rack with a bit of lithium grease during reassembly.
  9. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 9、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 9、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 9、 3の画像 3
    • Use a 1/2" wrench to unscrew the upper end of the throttle cable from the throttle control.
    • Slide the throttle cable down out of the bottom of the throttle control, and remove the cable.
  10. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: 手順 10、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement, Throttle Control: 手順 10、 2の画像 2
    • Use a Phillips #2 driver to remove the two screws securing the throttle control.
    • While removing the screws, use a 3/8" wrench to counter-hold the lock nuts and prevent them from rotating.
  11. Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 11、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Throttle Control Replacement: 手順 11、 2の画像 2
    • Remove the throttle control.
終わりに
4 の人々がこのガイドを完成させました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,716 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
コメント 1 件
the part # is incorrect, it appears that it is 440014 not 440013
JACOB - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 992
