メインコンテンツにスキップ
Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement
必要な工具と部品
  1. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: 手順 1、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: 手順 1、 2の画像 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 手順 2、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 手順 2、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 手順 2、 3の画像 3
    • Lift to raise the front end of the brush cutter.
    • Place a jack stand or other secure support under the deck to prevent the brush cutter from tipping forward.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 3、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 3、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 3、 3の画像 3
    • Use a 13/16" socket to remove the bolt securing the blade.
    • If needed, wedge a wood block between the blade and the deck to prevent the blade from turning.
    • During reassembly, make sure the blade is fully seated on the spindle, and use a torque wrench to tighten the bolt to 33-38 ft lbs.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 4、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 4、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 4、 3の画像 3
    • Wear gloves or be careful when handling the blade.
    • Remove the bolt and friction washer, and remove the blade.
    • Use a new bolt and washer when replacing the blade.
    • If the large cylindrical blade adapter falls off the spindle, check to make sure the key is correctly positioned inside the adapter, and then align the key with the notch on the spindle when installing it.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 5、 3の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 5、 3の画像 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 5、 3の画像 3
    • Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the top cover to the deck.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 6、 2の画像 1 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 6、 2の画像 2
    • Lift and remove the top cover.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 手順 7、 1の画像 1
    • Using a 9/16” socket or wrench, make sure the bolt at the top of the spindle is tight.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,518 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,198のガイドは作成済み
コメント 1 件
how about a part number for the replacement blade that you show how to change,
ALLAN - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 42
今までの合計 2,277
