メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Behringer Eurolive B212D Power PCB Replacement
必要な工具と部品
  1. Behringer Eurolive B212D Power PCB Replacement, Electronics Box: 手順 1、 1の画像 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    FixBotに聞いてみる
    コメントを追加
  2. Behringer Eurolive B212D Power PCB Replacement: 手順 2、 1の画像 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
    FixBotに聞いてみる
    コメントを追加
  3. Behringer Eurolive B212D Power PCB Replacement, Electronics Box: 手順 3、 3の画像 1 Behringer Eurolive B212D Power PCB Replacement, Electronics Box: 手順 3、 3の画像 2 Behringer Eurolive B212D Power PCB Replacement, Electronics Box: 手順 3、 3の画像 3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
    FixBotに聞いてみる
    コメントを追加
  4. Behringer Eurolive B212D Power PCB Replacement: 手順 4、 1の画像 1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
    FixBotに聞いてみる
    コメントを追加
  5. Behringer Eurolive B212D Power PCB Replacement: 手順 5、 3の画像 1 Behringer Eurolive B212D Power PCB Replacement: 手順 5、 3の画像 2 Behringer Eurolive B212D Power PCB Replacement: 手順 5、 3の画像 3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
    FixBotに聞いてみる
    コメントを追加
  6. Behringer Eurolive B212D Power PCB Replacement, Power & Control Panel: 手順 6、 2の画像 1 Behringer Eurolive B212D Power PCB Replacement, Power & Control Panel: 手順 6、 2の画像 2
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. Behringer Eurolive B212D Power PCB Replacement: 手順 7、 2の画像 1 Behringer Eurolive B212D Power PCB Replacement: 手順 7、 2の画像 2
    • Caution: The circuit board contains many capacitors that could cause serious injury if touched. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
    FixBotに聞いてみる
    コメントを追加
  8. Behringer Eurolive B212D Power PCB Replacement, Power PCB: 手順 8、 3の画像 1 Behringer Eurolive B212D Power PCB Replacement, Power PCB: 手順 8、 3の画像 2 Behringer Eurolive B212D Power PCB Replacement, Power PCB: 手順 8、 3の画像 3
    • Remove the 4 indicated 7/32" long machine screws with a #1 phillips head screwdriver.
    • Remove the box containing the power PCB.
    FixBotに聞いてみる
    コメントを追加
  9. Behringer Eurolive B212D Power PCB Replacement: 手順 9、 2の画像 1 Behringer Eurolive B212D Power PCB Replacement: 手順 9、 2の画像 2
    • There are 4 remaining 7/32" long machine screws holding the power PCB to the box which contains it; remove these with a #1 phillips head screwdriver.
    • Remove the power PCB.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Troy W. Weber
メンバー登録日: 03/29/12
1,506 ポイント
6のガイドは作成済み
14件のガイドコメント
This PCB does not convert electricity, and is rarely what fails. AC leaves this board and gets converted to DC at the rectifier bridge, which is part of the main amp PCB. This main amp board is where 99.9% of issues arise...
Gabriel Talamantes - 返信 共有
Do you know where I can find replacement boards for this speaker? It takes about 20 times of cycling the power button for it to finally come on. Can't seem to find parts anywhere. May not be financially smart to replace the board, but if it's not that expensive, I feel it's worth it.
Justin - 返信 共有
Hi. Why dont you fix the board?
riaandd - 返信 共有
Has anyone got a circuit diagram for the power board. Is it a switch mode power supply - the power plug indicates 240V or 110 V AC which would normally indicate it uses a switch mode power supply at the front end
Jonathon - 返信 共有
my fuse holder the plastic broke because there is not enough pressure to hold in the fuse and turns on and off
Jeffrey Martinez - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 109
今までの合計 22,685
