メインコンテンツにスキップ
Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement
必要な工具と部品
  1. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 手順 1、 3の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 手順 1、 3の画像 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 手順 1、 3の画像 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 2、 2の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 2、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 3、 3の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 3、 3の画像 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 3、 3の画像 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 4、 2の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 4、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 5、 3の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 5、 3の画像 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 5、 3の画像 3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: 手順 6、 3の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: 手順 6、 3の画像 2 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement, Vibration Motors: 手順 6、 3の画像 3
    • Locate the two solder points corresponding to the malfunctioning vibrational motor.
  7. Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 7、 2の画像 1 Beboncool Gamepad for Nintendo Switch Vibration Motors Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Desolder the two connection points corresponding to the malfunctioning vibration motor.
    • Once the solder has been sufficiently melted, carefully pull the wires away from the solder point with tweezers.
    • For help with soldering best practices, check out this Soldering and Desoldering Connections Guide.
終わりに
作成者
5人の作成者と共同で作成されました。
Patrick
メンバー登録日: 01/30/20
402 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 183
