はじめに
Rechargeable batteries only have so many cycles of charge and discharge. When the battery is no longer able to be recharged this does not mean that the the controller itself is bad, it simply means that a new, fresh battery is needed. This guide is written to help you replace the factory installed battery with a new one to continue to use your controller without having to buy a complete new one.
必要な工具と部品
Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
ある他の人がこのガイドを完成しました。
