メインコンテンツにスキップ
Beats Pill 1.0 Battery Replacement
必要な工具と部品
  1. Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 手順 1、 3の画像 1 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 手順 1、 3の画像 2 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 手順 1、 3の画像 3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
  2. Beats Pill 1.0 Battery Replacement, Removing Center Cover: 手順 2、 3の画像 1 Beats Pill 1.0 Battery Replacement, Removing Center Cover: 手順 2、 3の画像 2 Beats Pill 1.0 Battery Replacement, Removing Center Cover: 手順 2、 3の画像 3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Beats Pill 1.0 Battery Replacement, Separate the Device: 手順 3、 3の画像 1 Beats Pill 1.0 Battery Replacement, Separate the Device: 手順 3、 3の画像 2 Beats Pill 1.0 Battery Replacement, Separate the Device: 手順 3、 3の画像 3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: 手順 4、 2の画像 1 Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: 手順 4、 2の画像 2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: 手順 5、 2の画像 1 Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: 手順 5、 2の画像 2
    • Carefully remove the black and red NFC sensor wires.
  6. Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: 手順 6、 2の画像 1 Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: 手順 6、 2の画像 2
    • Carefully remove the control cables (4 black, 1 red).
    • Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
    • Gently remove the motherboard from the case
    • Remove the yellow NFC module with Tweezers
  7. Beats Pill 1.0 Battery Replacement, Remove the power button: 手順 10、 1の画像 1
    • Remove power button and springs.
  8. Beats Pill 1.0 Battery Replacement, Cut off battery: 手順 11、 1の画像 1
    • Cut off the battery wires
  9. Beats Pill 1.0 Battery Replacement, Attach new battery: 手順 12、 1の画像 1
    • Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
終わりに
27 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Paul Haas
メンバー登録日: 01/13/15
766 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 3-2, Hickman Winter 2015 USF Tampa, Team 3-2, Hickman Winter 2015人のメンバー
USFT-HICKMAN-W15S3G2
4 メンバー
6のガイドは作成済み
10 件のコメント
donde puedo comprar la batttery para pill beats
felix - 返信
Where can you buy the replacement battery
wtmcclure - 返信
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
jmestascatcoparco - 返信
Looks like the Bluetooth antenna
James Jenkins -
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 165
過去 30 日: 580
今までの合計 139,665
