メインコンテンツにスキップ
Battery Disconnect
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Battery Disconnect, Samsung Galaxy A51 SIM Tray Removal: 手順 1、 3の画像 1 Battery Disconnect, Samsung Galaxy A51 SIM Tray Removal: 手順 1、 3の画像 2 Battery Disconnect, Samsung Galaxy A51 SIM Tray Removal: 手順 1、 3の画像 3
    • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Battery Disconnect, Back Cover: 手順 2、 1の画像 1
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover to soften the adhesive.
    • The adhesive of the Samsung Galaxy A51 is very strong. You can use a hair dryer or a heat gun if you aren't able to open the device with the iOpener.
    • Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. Battery Disconnect: 手順 3、 3の画像 1 Battery Disconnect: 手順 3、 3の画像 2 Battery Disconnect: 手順 3、 3の画像 3
    • Insert the tip of an opening pick between the frame and the back cover at the bottom of the phone near the USB-C port.
    • If you can't get between the back cover and midframe with your opening pick, you can use a suction handle or strong tape to pull up the back cover to create a gap.
    • Slide the opening pick to the bottom right corner and leave it there.
  4. Battery Disconnect: 手順 4、 3の画像 1 Battery Disconnect: 手順 4、 3の画像 2 Battery Disconnect: 手順 4、 3の画像 3
    • Insert a second opening pick and slide it from the bottom right corner to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Battery Disconnect: 手順 5、 3の画像 1 Battery Disconnect: 手順 5、 3の画像 2 Battery Disconnect: 手順 5、 3の画像 3
    • Insert a third opening pick under the bottom left corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick along the left edge of the phone.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Battery Disconnect: 手順 6、 3の画像 1 Battery Disconnect: 手順 6、 3の画像 2 Battery Disconnect: 手順 6、 3の画像 3
    • Insert a fourth opening pick under the top left corner of the back cover near the camera.
    • Slide the tip of the opening pick along the top edge of the phone to the right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Battery Disconnect: 手順 7、 3の画像 1 Battery Disconnect: 手順 7、 3の画像 2 Battery Disconnect: 手順 7、 3の画像 3
    • With opening picks in all four corners, insert a fifth and final opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the right edge of the phone to the bottom right corner to cut the remaining adhesive.
  8. Battery Disconnect: 手順 8、 1の画像 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Battery Disconnect, Midframe: 手順 9、 1の画像 1
    • Remove the thirteen 3 mm Phillips #00 screws securing the midframe.
  10. Battery Disconnect: 手順 10、 3の画像 1 Battery Disconnect: 手順 10、 3の画像 2 Battery Disconnect: 手順 10、 3の画像 3
    • The midframe is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom of the phone near the charge port.
    • Slide the opening pick to the left bottom corner to release the plastic clips.
    • Slide the opening pick to the bottom right corner to release the rest of the bottom plastic clips.
  11. Battery Disconnect: 手順 11、 3の画像 1 Battery Disconnect: 手順 11、 3の画像 2 Battery Disconnect: 手順 11、 3の画像 3
    • Continue sliding the opening pick on the right side of your phone until all plastic clips on the right side are released.
  12. Battery Disconnect: 手順 12、 3の画像 1 Battery Disconnect: 手順 12、 3の画像 2 Battery Disconnect: 手順 12、 3の画像 3
    • Slide the opening pick along the top edge to release the top plastic clips.
  13. Battery Disconnect: 手順 13、 3の画像 1 Battery Disconnect: 手順 13、 3の画像 2 Battery Disconnect: 手順 13、 3の画像 3
    • Slide the opening pick from the top left corner to the bottom left corner to release the left side's plastic clips.
  14. Battery Disconnect: 手順 14、 1の画像 1
    • Remove the midframe.
  15. Battery Disconnect, Battery Disconnect: 手順 15、 2の画像 1 Battery Disconnect, Battery Disconnect: 手順 15、 2の画像 2
    • Use the flat end of a spudger to disconnect the battery by prying the connector straight up from its socket.
終わりに
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
56,450 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,468のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 8
今までの合計 56
