はじめに
Use this guide to replace a broken phone connector on your Backbone One.
必要な工具と部品
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
この手順で使用する道具:Tweezers$4.99
Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
6件のガイドコメント
Where can I find the connector
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
