はじめに
This guide will show the steps required to remove the motherboard from the device.
必要な工具と部品
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Is there any way to replace or repair the display ribbon cable? I snapped it and now I have no display.
Remove all four 15.5 mm PH2 screws holding the power supply down.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
actually there are four connections - one underneath at the top of the picture above
Simon Ward - 返信
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
5 の人々がこのガイドを完成させました。
5 件のコメント
Where do I can get the power supply?
where can i get the notherboard? 354437-0060
Please where can I get the motherboard
Where can I get the motherboard?
I am getting an error “Error code 0000. Contact Bose service” what do I do?
