メインコンテンツにスキップ
BLU Advance 4.0 Screen Replacement
必要な工具と部品
  1. 注意: 手順 1-3 は、作業進行中としてマークされている ガイド から引用されています。
    BLU Advance 4.0 Screen Replacement, Removing the back cover: 手順 1、 2の画像 1 BLU Advance 4.0 Screen Replacement, Removing the back cover: 手順 1、 2の画像 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 手順 2、 3の画像 1 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 手順 2、 3の画像 2 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 手順 2、 3の画像 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: 手順 3、 1の画像 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Screen Replacement, Screen: 手順 4、 2の画像 1 BLU Advance 4.0 Screen Replacement, Screen: 手順 4、 2の画像 2
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
  5. BLU Advance 4.0 Screen Replacement: 手順 5、 2の画像 1 BLU Advance 4.0 Screen Replacement: 手順 5、 2の画像 2
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: 手順 6、 1の画像 1
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Jon Sclar
メンバー登録日: 11/13/14
292 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 21
今までの合計 3,775
