メインコンテンツにスキップ
BLU Advance 4.0 Charger Port Replacement
必要な工具と部品
  1. 注意: 手順 1-3 は、作業進行中としてマークされている ガイド から引用されています。
    BLU Advance 4.0 Charger Port Replacement, Removing the back cover: 手順 1、 2の画像 1 BLU Advance 4.0 Charger Port Replacement, Removing the back cover: 手順 1、 2の画像 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: 手順 2、 3の画像 1 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: 手順 2、 3の画像 2 BLU Advance 4.0 Charger Port Replacement, Revealing the motherboard: 手順 2、 3の画像 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Charger Port Replacement, Separating motherboard from screen: 手順 3、 1の画像 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
  4. BLU Advance 4.0 Charger Port Replacement, Charger Port: 手順 4、 2の画像 1 BLU Advance 4.0 Charger Port Replacement, Charger Port: 手順 4、 2の画像 2
    • Once phone is completely disassmbled, you will take your soldering iron to the charger port to remove it.
    • Be careful to make sure you take a soldering wick to absorb the solder.
    • Touching other pieces on the motherboard may alter phones capabilities!
  5. BLU Advance 4.0 Charger Port Replacement: 手順 5、 1の画像 1
    • Once the old charger port is removed, take the new one and place it in the same spot. You will need to solder this piece to ensure that it stays connected.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jon Sclar
メンバー登録日: 11/13/14
292 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G2
3 メンバー
6のガイドは作成済み
コメント 1 件
Where can I get a charging port for my BLU studio XL2
Debbie - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 1,461
