メインコンテンツにスキップ
Azpen A909 Speaker Replacement
必要な工具と部品
  1. Azpen A909 Speaker Replacement, Back Cover: 手順 1、 1の画像 1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Speaker Replacement: 手順 2、 1の画像 1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Speaker Replacement: 手順 3、 1の画像 1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Speaker Replacement, Speaker: 手順 4、 1の画像 1
    • Gently peel back the black electrical tape covering the contact points between the speaker wires and the circuit board. The contact points are marked with a red box.
  5. Azpen A909 Speaker Replacement: 手順 5、 1の画像 1
    • Before you start soldering, it may be a good idea to check out the soldering and desoldering guide.
    • Melt the solder around the contact points with a soldering iron while using a de-soldering wick to absorb the melted solder.
    • Once the solder is removed from the contact points, pull the wires away from the circuit board contacts.
    • When attaching a new speaker, do not solder the two contact points together.
終わりに
作成者
2人の作成者と共同で作成されました。
Karoly Fodor
メンバー登録日: 03/15/15
475 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Duarte Spring 2015 UMass Dartmouth, Team 3-5, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 158
