はじめに
If your device won't turn on or doesn't hold a charge for very long, you might need to replace the battery. This guide will provide the steps to remove and install a battery in your Azpen A909.
必要な工具と部品
Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
Using a plastic opening tool, gently pry the edges battery off of the backside of the touchscreen display. Start at the end of the battery opposite the connecting wires.
Once the edges are free, slowly work inward with the opening tool until the battery is free. This may take some time, since copious amounts of adhesive were used to anchor the battery in place.
Pick a connection point and place the soldering iron on top of the wick above the existing solder ball.
Hold the soldering iron in place until the solder melts into the wick.
Repeat the same procedure on the remaining connector.
Lift the old battery off of the touchscreen. Make sure that all the solder has been removed before pulling the wires away from the board. The wires should come free with little to no resistance.
