メインコンテンツにスキップ
Azpen A701 Motherboard Replacement
必要な工具と部品
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: 手順 1、 1の画像 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: 手順 2、 2の画像 1 Azpen A701 Motherboard Replacement: 手順 2、 2の画像 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: 手順 3、 1の画像 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: 手順 4、 1の画像 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: 手順 5、 3の画像 1 Azpen A701 Motherboard Replacement, Motherboard: 手順 5、 3の画像 2 Azpen A701 Motherboard Replacement, Motherboard: 手順 5、 3の画像 3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: 手順 6、 3の画像 1 Azpen A701 Motherboard Replacement: 手順 6、 3の画像 2 Azpen A701 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: 手順 7、 1の画像 1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: 手順 10、 1の画像 1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: 手順 11、 1の画像 1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: 手順 12、 1の画像 1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Michael
メンバー登録日: 03/11/15
568 ポイント
4のガイドは作成済み
チーム
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G1
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 316
