メインコンテンツにスキップ
Audiovox CR8030iE5 Backlight Replacement
必要な工具と部品
  1. Audiovox CR8030iE5 Backlight Replacement, Top-Casing: 手順 1、 1の画像 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Backlight Replacement: 手順 2、 1の画像 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Backlight Replacement: 手順 3、 1の画像 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Backlight Replacement: 手順 4、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Backlight Replacement: 手順 5、 1の画像 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Backlight Replacement, Backlight: 手順 6、 1の画像 1
    • Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
  7. Audiovox CR8030iE5 Backlight Replacement: 手順 7、 1の画像 1
    • Carefully, pull up on the board to remove it entirely from the plastic casing.
  8. Audiovox CR8030iE5 Backlight Replacement: 手順 8、 1の画像 1
    • Flip the backlight board over to view the underside.
  9. Audiovox CR8030iE5 Backlight Replacement: 手順 9、 1の画像 1
    • One by one, de-solder the four wires (two wires corresponding to each LED bulb) that attach the backlight to the board.
    • If you don't know how to solder, check out はんだ付けとはんだ除去の作業ガイド.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  10. Audiovox CR8030iE5 Backlight Replacement: 手順 10、 1の画像 1
    • Remove the two LED light bulbs.
    • Insert each wire from the new LED bulbs into the respective holes.
  11. Audiovox CR8030iE5 Backlight Replacement: 手順 11、 1の画像 1
    • One by one, solder the backlight wires back into place.
終わりに
作成者
7人の作成者と共同で作成されました。
Nab Sengupta
メンバー登録日: 04/18/13
55 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G39
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 345
