メインコンテンツにスキップ
Audiovox CDM-8900 Keypad Replacement
必要な工具と部品
  1. Audiovox CDM-8900 Keypad Replacement, Battery: 手順 1、 2の画像 1 Audiovox CDM-8900 Keypad Replacement, Battery: 手順 1、 2の画像 2
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Keypad Replacement, Antenna: 手順 2、 3の画像 1 Audiovox CDM-8900 Keypad Replacement, Antenna: 手順 2、 3の画像 2 Audiovox CDM-8900 Keypad Replacement, Antenna: 手順 2、 3の画像 3
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  3. Audiovox CDM-8900 Keypad Replacement, Motherboard: 手順 3、 3の画像 1 Audiovox CDM-8900 Keypad Replacement, Motherboard: 手順 3、 3の画像 2 Audiovox CDM-8900 Keypad Replacement, Motherboard: 手順 3、 3の画像 3
    • Remove the small rubber insert from the top of the phone to access the top screw.
    • Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
    • If screws do not slide out after unscrewing, gently flip and tap the phone in your hand until the screws come loose.
  4. Audiovox CDM-8900 Keypad Replacement: 手順 4、 3の画像 1 Audiovox CDM-8900 Keypad Replacement: 手順 4、 3の画像 2 Audiovox CDM-8900 Keypad Replacement: 手順 4、 3の画像 3
    • Wedge the phone plate toward you, using the leverage from an opening tool.
    • The volume control button on the left side of the phone will loosen. Make sure to carefully reinsert it during reassembly.
    • Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
  5. Audiovox CDM-8900 Keypad Replacement: 手順 5、 3の画像 1 Audiovox CDM-8900 Keypad Replacement: 手順 5、 3の画像 2 Audiovox CDM-8900 Keypad Replacement: 手順 5、 3の画像 3
    • To release the motherboard, push the large "OK" button located on the other side of the phone.
    • Before reassembly, make sure the keypad is lined up with the motherboard. Be sure the camera lens is properly aligned at the top of the motherboard and the volume controls are in place.
  6. Audiovox CDM-8900 Keypad Replacement, Keypad: 手順 6、 1の画像 1
    • Peel away keypad from faceplate.
ゴール
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Aaron Shaw
メンバー登録日: 04/15/10
177 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G31
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 1,981
