メインコンテンツにスキップ
Audio Technica ATH-AD500 Left Headphone Cable Replacement
必要な工具と部品
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: 手順 1、 1の画像 1
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - 返信
    How to install the earpads
    rangaranju - 返信
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 2、 1の画像 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 3、 1の画像 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 手順 4、 3の画像 1 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 手順 4、 3の画像 2 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 手順 4、 3の画像 3
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference はんだ付けとはんだ除去の作業ガイド.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 5、 2の画像 1 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 5、 2の画像 2
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
    “Thread the replacement cable into the hole on the bottom of the headphones“ what replacement cables?
    John S - 返信
    Hey, read my comment on the bottom of the guide if it’s still relevant to you.
    Erez Dahan -
    I have the same question, what replacement cable do I need?
    Erez Dahan - 返信
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 6、 3の画像 1 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 6、 3の画像 2 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 手順 6、 3の画像 3
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference はんだ付けとはんだ除去の作業ガイド.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Melanie Reis
メンバー登録日: 01/11/13
227 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G19
6 メンバー
17のガイドは作成済み
2 件のコメント
Thank you so much! your guide helped me repair my AD900x!
Anwar X - 返信
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 78
今までの合計 9,683
