メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Asus ZenFone 5 Battery Replacement
必要な工具と部品
  1. Asus ZenFone 5 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Heat up the iOpener in the microwave for 30 seconds.
    • Caution: when the iOpener is heated up, hold it by the sides to prevent bodily harm.
  2. Asus ZenFone 5 Battery Replacement: 手順 2、 1の画像 1
    • Place the iOpener on the side of the phone until the iOpener gets cool (approximately 10-15 minutes).
    • Reheat the iOpener and reapply it to the other side of the phone.
  3. Asus ZenFone 5 Battery Replacement: 手順 3、 2の画像 1 Asus ZenFone 5 Battery Replacement: 手順 3、 2の画像 2
    • Gently slide the jimmy along the edges of the phone to break the adhesive.
    • Use opening picks and the opening tool to pry the back cover off.
    • The use of metal tools as shown in the photos is potentially dangerous as the battery is exposed along the edges of the case and risk of puncture is high. Choose an ESD safe tool instead.
    • There are 6 different tabs on each side of the phone that might take force to get apart.
    • Repeat the heating and prying process until the back cover can be fully removed.
  4. Asus ZenFone 5 Battery Replacement: 手順 4、 2の画像 1 Asus ZenFone 5 Battery Replacement: 手順 4、 2の画像 2
    • Use the #00 phillips head to take out the six phillips #00 3.175mm screws on the top cover plate.
    • Use the spudger to release the clasps along the edge of the top plate.
  5. Asus ZenFone 5 Battery Replacement: 手順 5、 1の画像 1
    • Disconnect the press fit connector located near the upper right corner of the battery to disengage the battery from the motherboard.
  6. Asus ZenFone 5 Battery Replacement: 手順 6、 2の画像 1 Asus ZenFone 5 Battery Replacement: 手順 6、 2の画像 2
    • Use the same screwdriver to remove the five phillips #00 3.96mm screws along the bottom plate.
    • Use the spudger to pry the bottom plate off.
  7. Asus ZenFone 5 Battery Replacement: 手順 7、 2の画像 1 Asus ZenFone 5 Battery Replacement: 手順 7、 2の画像 2
    • Pull on the two black tabs on the bottom of the battery until the battery is released.
    • Gently pull the battery out of its socket.
終わりに
To put the battery back in, replace the orange tab on the top of the battery on its socket.
作成者
5人の作成者と共同で作成されました。
Rachel Goldstein
メンバー登録日: 07/08/19
169 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 20
今までの合計 3,754
