メインコンテンツにスキップ
Asus X553MA-BPD07051 Battery Replacement
必要な工具と部品
ビデオの概要
  1. Asus X553MA-BPD07051 Battery Replacement, Battery: 手順 1、 2の画像 1 Asus X553MA-BPD07051 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
    • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
  2. Asus X553MA-BPD07051 Battery Replacement: 手順 2、 1の画像 1
    • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
    • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
  3. Asus X553MA-BPD07051 Battery Replacement: 手順 3、 2の画像 1 Asus X553MA-BPD07051 Battery Replacement: 手順 3、 2の画像 2
    • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
    • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
  4. Asus X553MA-BPD07051 Battery Replacement: 手順 4、 1の画像 1
    • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
    • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard.
  5. Asus X553MA-BPD07051 Battery Replacement: 手順 5、 2の画像 1 Asus X553MA-BPD07051 Battery Replacement: 手順 5、 2の画像 2
    • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
  6. Asus X553MA-BPD07051 Battery Replacement: 手順 6、 2の画像 1 Asus X553MA-BPD07051 Battery Replacement: 手順 6、 2の画像 2
    • Lift the battery up and remove it completely from the laptop.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Stephanie DeCarvalho
メンバー登録日: 10/21/19
898 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G4, Botvin Fall 2019 UMass Dartmouth, Team S1-G4, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G4
3 メンバー
5のガイドは作成済み
2 件のコメント
I used your guide when i repaired my mates X553. I found it quite easy. So thanks for the heads up on what to look out for :-)
gazza667 - 返信
Easy with the use of these clear instructions. Thanks and keep up the good work.
Marc Leclair - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 2,238
