メインコンテンツにスキップ
Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement
必要な工具と部品
  1. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 2、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 2、 2の画像 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 3、 3の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 3、 3の画像 2 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 3、 3の画像 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 4、 1の画像 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Battery: 手順 5、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Battery: 手順 5、 2の画像 2
    • Using a Phillips #1 Screwdriver remove the six 3 mm screws keeping the battery in place.
  6. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 6、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 6、 2の画像 2
    • Unplug the battery connector from the mother board.
  7. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 7、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 7、 2の画像 2
    • Gently remove the battery from the slot.
  8. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Fan and Heatsink: 手順 8、 3の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Fan and Heatsink: 手順 8、 3の画像 2 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Fan and Heatsink: 手順 8、 3の画像 3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  9. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 9、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 9、 2の画像 2
    • Remove the wire connecting the fan to the motherboard.
  10. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 10、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 10、 2の画像 2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
  11. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Motherboard: 手順 11、 1の画像 1
    • Remove the four 4.0 mm Phillips #1 screws shown.
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the three 3.0 mm Phillips #1 screws shown.
  12. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 12、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 12、 2の画像 2
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
    • Pull the hinge the rest of the way up.
  13. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 13、 1の画像 1
    • Disconnect the motherboard from the two connectors shown.
  14. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 14、 1の画像 1
    • Disconnect the motherboard from the connector shown.
  15. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 15、 1の画像 1
    • Pull the motherboard loose.
  16. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 16、 1の画像 1
    • Disconnect the motherboard from the connector shown and it is now removed from your device.
  17. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement, Track Pad: 手順 17、 1の画像 1
    • Remove the four 2.0 mm Phillips #1 screws holding the track pad in place.
  18. Asus Vivobook Q301LA-BHI5T02 Track Pad Replacement: 手順 18、 1の画像 1
    • Remove the tape connecting the track pad to the frame of the device. The track pad is now completely disconnected from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Samuel Foster
メンバー登録日: 11/06/18
157 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 253
