メインコンテンツにスキップ
Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement
必要な工具と部品
  1. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 2、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 2、 2の画像 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 3、 3の画像 1 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 3、 3の画像 2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 3、 3の画像 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 4、 1の画像 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 手順 5、 3の画像 1 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 手順 5、 3の画像 2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 手順 5、 3の画像 3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  6. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 6、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 6、 2の画像 2
    • Remove the wire connecting the fan to the motherboard.
  7. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 7、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 手順 7、 2の画像 2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
終わりに
作成者
4人の作成者と共同で作成されました。
Royce Gunter
メンバー登録日: 10/02/17
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S10-G3, Thompson Fall 2017 USF Tampa, Team S10-G3, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 588
