はじめに
A battery is required to run and use laptops. Unfortunately, the battery of the Asus VivoBook Max X541UV-BH71-CB laptop is poor compared to other laptops. The battery will quickly drain after going through excessive charging cycles. If the laptop battery is draining significantly quicker than normal or not charging, then the battery should be replaced. Before you begin the process of removing the battery, power off the laptop and disconnect the laptop from any external power source.
必要な工具と部品
ある他の人がこのガイドを完成しました。
コメント 1 件
Does anybody has a link to buy the battery replacement? Either original or generic. Thank you!
