はじめに
This guide will show you how to remove the battery from an Asus U50F-RBBAG05 Series laptop. The battery supplies power to the laptop, so this can fix the problem of the laptop not powering on. You must remove the battery if you need to “power discharge” the laptop. This guide can be found in the troubleshooting page.
Turn the laptop over so the bottom is facing up.
Slide the two tabs on the bottom of the laptop toward the edges of laptop.
Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
