メインコンテンツにスキップ
Asus Transformer Book T100TAF Keyboard Replacement
必要な工具と部品
  1. Asus Transformer Book T100TAF Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Keyboard Replacement: 手順 2、 2の画像 1 Asus Transformer Book T100TAF Keyboard Replacement: 手順 2、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws on the underside of the device.
  3. Asus Transformer Book T100TAF Keyboard Replacement: 手順 3、 2の画像 1 Asus Transformer Book T100TAF Keyboard Replacement: 手順 3、 2の画像 2
    • Use a metal spudger to pry up the rubber pads covering the two upper silver screws.
    • Use a Phillips #00 screwdriver to remove the two 5.5 mm screws under the rubber pads.
  4. Asus Transformer Book T100TAF Keyboard Replacement: 手順 4、 3の画像 1 Asus Transformer Book T100TAF Keyboard Replacement: 手順 4、 3の画像 2 Asus Transformer Book T100TAF Keyboard Replacement: 手順 4、 3の画像 3
    • Remove the back cover.
    • Use a Phillips #00 screwdriver to remove all the screws from the metal, inside panel, including four black 4.0 mm screws along the top.
    • Remove four black 3.0 screws along the bottom.
    • Remove the one silver 5.0 mm screw in the top right corner.
  5. Asus Transformer Book T100TAF Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the metal keyboard cover from the device.
  6. Asus Transformer Book T100TAF Keyboard Replacement: 手順 6、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the 4.5 mm screw on the keyboard circuit board.
  7. Asus Transformer Book T100TAF Keyboard Replacement: 手順 7、 1の画像 1
    • Peel the yellow tape and label away from the motherboard with the metal spudger.
  8. Asus Transformer Book T100TAF Keyboard Replacement: 手順 8、 1の画像 1
    • Unplug the cable which leads to the hinge by gently pulling it away from the motherboard.
  9. Asus Transformer Book T100TAF Keyboard Replacement: 手順 9、 3の画像 1 Asus Transformer Book T100TAF Keyboard Replacement: 手順 9、 3の画像 2 Asus Transformer Book T100TAF Keyboard Replacement: 手順 9、 3の画像 3
    • Flip up the tab on the white ribbon cable labeled “MB” using the metal spudger and then pull the white ribbon cable away from the motherboard.
    • Use a spudger to carefully flip up the black tab on the ZIF connector and pull the black striped ribbon cable away from the motherboard.
    • Don't use a metal spudger for work on the internals of your laptop. The photo in this guide is incorrect. The metal spudger is not ESD safe and could harm the components in your laptop.
  10. Asus Transformer Book T100TAF Keyboard Replacement: 手順 10、 1の画像 1
    • Gently remove the motherboard from the keyboard by pulling up with even pressure applied to all sides of the board.
終わりに
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Elizabeth
メンバー登録日: 10/01/16
589 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S4G3
4 メンバー
10のガイドは作成済み
コメント 1 件
Très facile. Merci. Et le fait d'avoir pu démonter mon clavier et souffler la poussière à l'intérieur à fait en sorte que les touches qui ne fonctionnaient plus ont recommencé à le faire. Merci encore.
Etienne Olemba - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 21
今までの合計 7,260
