メインコンテンツにスキップ
Asus ROG G751JL-BB17T29 Hard Drive Replacement
必要な工具と部品
  1. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 手順 1、 2の画像 1 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Remove the RAM access door: 手順 1、 2の画像 2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 2、 1の画像 1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 3、 2の画像 1 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 3、 2の画像 2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 4、 3の画像 1 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 4、 3の画像 2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 4、 3の画像 3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 5、 1の画像 1
    • Remove the RAM access door.
  6. Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 手順 6、 2の画像 1 Asus ROG G751JL-BB17T29 Hard Drive  Replacement, Hard Drive: 手順 6、 2の画像 2
    • Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
    • Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
  7. Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 7、 3の画像 1 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 7、 3の画像 2 Asus ROG G751JL-BB17T29 Hard Drive  Replacement: 手順 7、 3の画像 3
    • Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Kyle Miller
メンバー登録日: 10/06/16
677 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 2-1, Sullivan Fall 2016 USF Tampa, Team 2-1, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S2G1
4 メンバー
20のガイドは作成済み
コメント 1 件
Dose the Asus ROG G751JL have any m.2 port in there anywhere? And what is the maximum capacity of SSD use in the Asus ROG G751JL?
shohebulalam - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 5,847
