メインコンテンツにスキップ
Asus MeMO Pad HD 7 Battery Replacement
必要な工具と部品
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 手順 1、 3の画像 1 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 手順 1、 3の画像 2 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 手順 1、 3の画像 3
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
    Important: Remove SD card first!
    Ola Eldøy - 返信
  2. Asus MeMO Pad HD 7 Battery Replacement: 手順 2、 1の画像 1
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: 手順 3、 1の画像 1
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 手順 4、 3の画像 1 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 手順 4、 3の画像 2 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 手順 4、 3の画像 3
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
    I don't think you need to do this step (my motherboard came out and back in just fine, I just had to keep the battery cord out of the way, which is way easier than prying the whole thing out of there).
    Daniel Williams - 返信
終わりに
14 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Julien Daigle
メンバー登録日: 01/20/15
1,235 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 11-3, Blackwell Winter 2015 USF Tampa, Team 11-3, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S11G3
4 メンバー
5のガイドは作成済み
4 件のコメント
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - 返信
How did you fix the sd card port?
yanisstavrou - 返信
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - 返信
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 20
今までの合計 21,981
