はじめに
The Asus K55A-Si50301P Battery Replacement Guide explains the tolls and processes used to replace/remove the battery component as needed. Batteries may be dead/faulty if a laptop will not hold consistent charge levels. Other symptoms may include an inability to power on during the boot up phase of the system. No tools will be needed for the completion of removing/replacing this product. The Asus K55A-Si50301P Troubleshooting page may be referred to here as needed.
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
ある他の人がこのガイドを完成しました。
