メインコンテンツにスキップ
Asus G75VW-BHI7N07 USB Port Replacement
必要な工具と部品
  1. Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 手順 1、 3の画像 1 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 手順 1、 3の画像 2 Asus G75VW-BHI7N07 USB Port Replacement, USB Port: 手順 1、 3の画像 3
    • Remove the screws around the back cover using a Phillips #1 screwdriver.
    • Take the back cover off using the opening tool.
  2. Asus G75VW-BHI7N07 USB Port Replacement: 手順 2、 3の画像 1 Asus G75VW-BHI7N07 USB Port Replacement: 手順 2、 3の画像 2 Asus G75VW-BHI7N07 USB Port Replacement: 手順 2、 3の画像 3
    • Once you get rid of the back cover, spot all the screws marked ‘A’. There should be 10 in total.
    • Remove the battery using the slide release button.
    • This should expose 2 more ‘A’ marked screws.
    • Remove those using the same screwdriver.
  3. Asus G75VW-BHI7N07 USB Port Replacement: 手順 3、 2の画像 1 Asus G75VW-BHI7N07 USB Port Replacement: 手順 3、 2の画像 2
    • Using the opening tool, remove the disc drive cover.
    • Spot the 6 ‘B’ marked screws and remove them using the Phillips #1 screwdriver.
  4. Asus G75VW-BHI7N07 USB Port Replacement: 手順 4、 2の画像 1 Asus G75VW-BHI7N07 USB Port Replacement: 手順 4、 2の画像 2
    • Using the opening tool, pry open the keypad platform.
    • You will need to use your hands to get to the laptop’s internal systems by lifting the keypad platform.
  5. Asus G75VW-BHI7N07 USB Port Replacement: 手順 5、 3の画像 1 Asus G75VW-BHI7N07 USB Port Replacement: 手順 5、 3の画像 2 Asus G75VW-BHI7N07 USB Port Replacement: 手順 5、 3の画像 3
    • Now that the fans are exposed, use the opening tool to unhook them at the 4 connecting points.
    • Detach the blue-colored electrical component using the opening tool.
    • Detach the white and black colored electrical component using the opening tool.
  6. Asus G75VW-BHI7N07 USB Port Replacement: 手順 6、 1の画像 1
    • Using the Phillips #0 Screwdriver, remove the 5 screws around the edges of the motherboard.
    • Remove the 2 screws around the fan using the Phillips #0 Screwdriver which should be near the motherboard.
  7. Asus G75VW-BHI7N07 USB Port Replacement: 手順 7、 1の画像 1
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Joy
メンバー登録日: 09/08/17
437 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team S1-G1, Virtue Fall 2017 Western Carolina University, Team S1-G1, Virtue Fall 2017人のメンバー
WCU-VIRTUE-F17S1G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 604
