はじめに
This guide is for replacement of a defective keyboard on the Asus G53JW-A1 laptop. Removing this part is essential for further repairs on this device.
必要な工具と部品
There are five tabs underneath the keyboard that hold the keyboard in place along the top edge. Refer to the photo for a rough idea of the location of these tabs.
Using the spudger and iFixit Opening Tool at the indicated locations, pry the keyboard directly up. Ensure that the tools reach under both the plastic keyboard cover and the metal base of the keyboard, as both will be removed.
Remove the keyboard.
この手順で使用する道具:Tweezers$4.99
Lift the keyboard so that you can see the housing and cables underneath. Be sure you lifted the metal baseplate of the keyboard and not just the plastic covering.
This will reveal a ribbon wire on the right side of the laptop connected to the motherboard through a small window in the metal top plate. Use tweezers to carefully pull the connector gently to the left, unplugging it from its port.
To reassemble your device, follow these instructions in reverse order. i.e. plugging in the ribbon cables, then snapping the clips into position using the bottom hinge as a guide.
