メインコンテンツにスキップ
Asus EeeBook X205TA Battery Replacement
必要な工具と部品
  1. Asus EeeBook X205TA Battery Replacement, Battery: 手順 1、 2の画像 1 Asus EeeBook X205TA Battery Replacement, Battery: 手順 1、 2の画像 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: 手順 2、 1の画像 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: 手順 3、 2の画像 1 Asus EeeBook X205TA Battery Replacement: 手順 3、 2の画像 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: 手順 4、 1の画像 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: 手順 5、 1の画像 1
    • Carefully lift the battery out of the laptop.
    Very well explained with clear pictures. Thanks!
    Şerife Balci - 返信
終わりに
Follow the guide in reverse order to reassemble the device.
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Lorena Santiago
メンバー登録日: 10/06/16
712 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S2G2
3 メンバー
10のガイドは作成済み
11 件のコメント
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - 返信
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - 返信
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - 返信
my laptop is running on AC but the minute power is switched off it shuts. do i need a battery replacement?
kiranmayi kola - 返信
Mine was doing the exact same thing. I replaced the battery and it is working fine. There are known battery issues with this model.
Goran Jandjel -
Merci beaucoup tutoriel bien expliqué
tandem.2010 - 返信
I found my old ASUS X205TA and the battery was dead, it would still work with AC power though. I ordered a replacement battery and used this simple guide. All went well. Thanks.
Goran Jandjel - 返信
This should be a #0 Phillips driver, not a #2 Phillips driver!
Nathan Hui - 返信
Can anyone share links from where to order battery. I'm located in India. Thanks
saquib - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 24
過去 30 日: 77
今までの合計 14,516
