はじめに
This guide will show you how to replace a I/O board in an Asus A53S.
An I/O board allows you to connect a wide range of devices to your laptop.
Before using this guide, make sure to review the troubleshooting page. Most USB-related issues can be solved without removing the I/O board.
Make sure to power off your laptop completely, disconnect from any external power source, and remove the battery before beginning the process.
必要な工具と部品
Flip the laptop so the underside is facing up.
Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
Remove the back plate.
3 の人々がこのガイドを完成させました。
